Enables or disables password authentication using RADIUS for SSH2 x509v3 publication-key authentication.
| x509v3 | Specifies x509v3 public-key authentication. |
| radius-password-auth | Specifies to obtain the password from the user and authenticate it using RADIUS server for X509v3 public-key authentication. |
| on | Specifies to enable password authentication using RADIUS for X509v3 public-key authentication. |
| off | Specifies to disable password authentication using RADIUS for X509v3 public-key authentication. (Default). |
Off.
The following example enables password authentication using RADIUS for X509v3 public-key authentication.
# configure ssh2 x509v3 radius-password-auth on Note: When turned on, user provides password for RADIUS authentication. If RADIUS is not configured, local authentication is used.
This command was first available in ExtremeXOS 32.2.
